This is kind of weird and just started happening a couple of days ago...
1) Battery remains full charged on the road even with the fridge on battery mode.
2) Battery remains charged while sitting during the day with the solar panels deployed, fan running, fridge on propane.
3) Battery slowly goes down after dark with generator running. AC outlets working fine, am able to charge computer and camera battery.
Don't know if this is related but the iPad seems to charge very slowly when plugged into the T@B cigarette lighter.
Any ideas?
0 ·
Fuse diagram:
http://tab-rv.vanillaforums.com/discussion/954/fuse-diagram-information/p1
Jenn - Reset circuit breakers so we'll see.
ChanW - Pulled #6, looks ok.
Am on the road so will have to see the next time I pull the generator out.
Can you swap the fuse for a known good fuse, PXLated? Or put a volt ohm meter across the ends of the #6 fuse to make sure it is good.
