Info
Rhonda1216
Rhonda1216 Member Posts: 4
Info
  • bergger
    The windows generally have some side to side play in them.  Open the window and slide it to the other side and see if that helps it get close enough to latch.  I normally have to slide over our front window every once in a while to realign it.
    2021 T@b 400 BD  "Vixen Gail"
    Leadville Colorado
    Denny16 Member Posts: 5,430
    edited July 2022
    Rhonda, welcome to the TaB forum.  To realign yiur window, You slightly open the window so it clears the side seals, the ipen and close slightly whilst pushing the window sideways towards the side the latch does not reach.  This will center the window so it will latch on both sides.  You can do the same with the 400’s front window.  As Bergger said, both windows slide sideways and occasionally need to be realigned.
  • dragonsdofly
    @Rhonda1216 welcome to the forum. A wealth of information and experience here with great folks and advise. Good luck and let us know how your realignment goes. -Denise
  • Rhonda1216
    edited December 2023
    Thank you,
