Best lubricant for Keder rails?
CCC
Member Posts: 118
The search function here is poor and I prefer more up tot date recommendations anyway. Silicone spray or something else, getting https://pahaque.com/collections/trailer-shades/products/t-b-320-trailer-awning-silver-black-trim which seems like the best of both worlds, not too hot but offers shelter from wind and rain.
2022 T@B 320 S Boondock "UGA", Jeep Gladiator Overland
North Georgia
North Georgia
My experience is the Visor (for example) 'jams' during installation due to the 'cable end' hitting a screw head.
No lubricant will fix that . . . .'18 320 S, pitched axle, 3020HE; PNW based
@MuttonChops CCC has a newer model with the better keder rail/flatter screw heads, so that should be less of an issue.
@CCC I use silicone spray (WD40 silicone, to be specific) as per other recs here on the forum. It made quite a bit of difference, though like MuttonChops, I have the raised screw heads to deal with.2019 320s BD Lite, white with blue (“Haven”)
Pacific NW1 -
I highly recommend Boeshield T-9. It is pricy but it won't attract dust and grit like WD-40. It is wax based rather than petroleum based.1
I have considered replacing the screws to eliminate this issue as it is very annoying. My 2009 Dutchman T@B did not have this issue.MuttonChops said:My experience is the Visor (for example) 'jams' during installation due to the 'cable end' hitting a screw head.
No lubricant will fix that . . . .2009 Dutchman TQ - Sold
2021 CS-S - Enjoying the new layout
2011 Outback 3.6r0 -
Hi,
There is a product called sailkote that is used to help sails slide in a similar slot. Works real well to help sails with a bolt rope slide in the groove. It’s a dry lubricant.2025 360 CS
Southern Maryland3 -
We used Lemon Pledge furniture spray....it was recommended to us by others and works great.2015 Little Guy T@B 320 Max White with Red trim
Pulled by a 2023 Toyota Tundra
Leaves on T@bventures from the Snoqualmie Valley, WA
I removed each screw in the Keder rail, one by one, and countersunk each hole. Screws now sit nearly flush.
2020 T@B 400 Boondock Lite.
2020 Chevrolet Colorado ZR2
with the 2.8 litre 4-cylinder Duramax diesel.
I sprayed teflon into the rail. Slides through with ease now.2021 Tab 400 Boondock
2020 Audi SQ50 -
Did you have a small CounterSink bit to fit between rail or did you use a drill?swiftwave said:I removed each screw in the Keder rail, one by one, and countersunk each hole. Screws now sit nearly flush.
I am doing this soon but my Countersink bits are too big I need to find a smaller one.2009 Dutchman TQ - Sold
Here was my contribution to this subject..
https://tab-rv.vanillacommunity.com/discussion/comment/193617/#Comment_193617
-Brian in Chester, Virginia
RV: 2018 T@B 320S, >100 mods1
