Best lubricant for Keder rails?
CCC
CCC Member Posts: 118
The search function here is poor and I prefer more up tot date recommendations anyway. Silicone spray or something else, getting https://pahaque.com/collections/trailer-shades/products/t-b-320-trailer-awning-silver-black-trim which seems like the best of both worlds, not too hot but offers shelter from wind and rain.
2022 T@B 320 S Boondock  "UGA", Jeep Gladiator Overland
North Georgia
    MuttonChops Member Posts: 2,057
    My experience is the Visor (for example) 'jams' during installation due to the 'cable end' hitting a screw head.
    No lubricant will fix that . . . .
  • VictoriaP
    VictoriaP Member Posts: 1,496
    @MuttonChops CCC has a newer model with the better keder rail/flatter screw heads, so that should be less of an issue.
    @CCC I use silicone spray (WD40 silicone, to be specific) as per other recs here on the forum. It made quite a bit of difference, though like MuttonChops, I have the raised screw heads to deal with.
  • falcon1970
    falcon1970 Member Posts: 758
    I highly recommend Boeshield T-9.  It is pricy but it won't attract dust and grit like WD-40.  It is wax based rather than petroleum based.
  • tomtek
    tomtek Member Posts: 48
    I have considered replacing the screws to eliminate this issue as it is very annoying.   My 2009 Dutchman T@B did not have this issue.
    2009 Dutchman TQ - Sold
    2021 CS-S - Enjoying the new layout
    2011 Outback 3.6r
  • Yoshi_TAB
    Yoshi_TAB Member Posts: 592
    Hi,
    There is a product called sailkote that is used to help sails slide in a similar slot.  Works real well to help sails with a bolt rope slide in the groove.  It’s a dry lubricant.
    2025 360 CS
    Southern Maryland
  • TheBellHop
    TheBellHop Member Posts: 20
    We used Lemon Pledge furniture spray....it was recommended to us by others and works great.
    2015 Little Guy T@B 320 Max White with Red trim
    Pulled by a 2023 Toyota Tundra
    Leaves on T@bventures from the Snoqualmie Valley, WA
  • swiftwave
    swiftwave Member Posts: 50
    I removed each screw in the Keder rail, one by one, and countersunk each hole.  Screws now sit nearly flush.
    2020 T@B 400 Boondock Lite.
    2020 Chevrolet Colorado ZR2
    with the 2.8 litre 4-cylinder Duramax diesel.
  • dlb
    dlb Member Posts: 176
    I sprayed teflon into the rail.  Slides through with ease now.
    2021 Tab 400 Boondock
    2020 Audi SQ5
  • tomtek
    Did you have a small CounterSink bit to fit between rail or did you use a drill?
    I am doing this soon but my Countersink bits are too big I need to find a smaller one.
    2011 Outback 3.6r
  • BrianZ
    BrianZ Member Posts: 1,770
