'20 T@b400 bath door hinges
On a trip, and just discovered one hinge (top) has broken, and another is well on its way. No helpful numbers printed on it ('HR US PAT 7.594.300' is all, and not useful to Google). As Murphy would have it, of course we're on a trip and it's the weekend, Tab400 searches reveal little.
Has anyone had to replace one, and if so, do you have a part number, hopefully via Amazon?
Also, I'd suggest checking that all your hinge screws are secure, as some were a bit loose. Not sure if this worked into the failure or not.
Thanks for any info!
-Jeff
2020 T@B400 Boondock Lite w/solar
2024 T@g 5-wide Black Canyon
TV is 2024 Toyota Land Cruiser LCP
Jeff --Front Range of Colorado
  • DenisP
    DenisP Member Posts: 542
    Had the same hinge break on my 2018 400 while camping in Maine. I took the hinge to Rockler’s woodworking store and they had a matching hinge (bought 4 just in case, replaced one). The new hinge is made of steel unlike the broken one which has cast parts.
    2013 Tundra TRD 5.7L
    Massachusetts
  • b407driver
    b407driver Member Posts: 139
    I'm off the beaten track, so no physical searching for me. Good to know they can be found!
  • jschmier
    jschmier Member Posts: 26
    edited September 2022
    Had to replace mine.  Contact Cristina.Zapata@HardwareResources.com.  Part# is 22855. Telephone- 800.463.0660 (O) | 21713 (EXT).  I went through a distributor in Troy, MI  Herald Wholesale.  Four hinges cost less than $10, figured if one broke... Took about a week.
    2018 T@B 400/solar/2022 Honda Ridgeline
    Denny16 Member Posts: 5,430
    I got my replacement hinges from nüCamp through my dealer.
  • b407driver
    Thank you for that!
  • vhollow
    vhollow Member Posts: 99
    Another source is Knobs4Less. The part is Hardware Resources 22855-8-000N-2. They sell for $1.79 each. Because they are cast metal, they do tend to break under the weight of the door, especially if any screw holes in the frame are stripped. Forged steel would be much better. To repair stripped frame holes, pack them full of JB Weld, and redrill smaller than the screw after it sets (or use any epoxy resin putty). Even better, if you have plastic molding on the door frame, replace it with aluminum channel (there are links on the forum about this). The rigid metal molding helps prevent the screws from stripping. Here is a link for the hinges: https://www.knobs4less.com/Hardware-Resources-Adjustable-Hinge/hr228558000n.html
  • b407driver
    Thanks you all for the info! Just got back from 12 days in the road, and luckily the door didn't fall off the two hinges. Got a maintenance list including the dreaded Alde 'gas failure', so have some homework to do. THANKS AGAIN!
    Gas failure occurs when the gas bottle is turned off, or the remain gas in the tank drops below 25% remaining gas level.  I had this when the gas volume in the bottle dropped, even though the stove worked, the Alde would not light.  Refilled the gas bottle, and problem fixed, Alde retuned to normal operation on gas.
