Tree sap on acrylic windows removal!
CanadianTabber
Member Posts: 148
Hi all!
Tree sap removal on acrylic windows recommendations?
Thanks!
Thanks!
2021 Tab 320s Boondock-2016 Toyota Venza V6
Toronto, Canada
Toronto, Canada
WD-40 or even olive oil works. As I understand it, the other technique of rubbing alcohol (or hand sanitizer) is not recommended for acrylic.
2018 T@B 320S / 2017 Subaru Outback / Seattle, WA1 -
Thank you..will try it!2021 Tab 320s Boondock-2016 Toyota Venza V6
Toronto, Canada0 -
@CanadianTabber, try "Goo-Gone." I used it to remove some stickers from the acrylic windows when I purchased it (in 2019) and use it on the aluminum body to remove tree sap. If you're not sure, test it first on an inconspicuous area of the acrylic window first.
Purell hand sanitizer!2016 T@B CS/ 2014 Toyota FJ Cruiser2
