Fresh water overflow leaking while driving
Greenbean
Member Posts: 3
Has anyone had issues with water coming from fresh water overflow tube while driving? I lost 1/3 of my water driving to my destination this weekend. When I would make right hand turns I could see a lot of water coming from the driver side trailer behind the wheel. I have a 2022 Tab 400 Boondock edition and have used it about 10 times this summer with no issues until this last trip. I plugged the fresh water overflow tube and drove around with no leaks. I then unplugged the tube and drove around with water leaking during right hand turns. I don't take turns and curves fast.
This would be good info for the nuCamp team. Help@nucamprv.comSharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
I have a 2022 320 boondock . Same issue. This is the second weekend where we ran out of waterMichael Godshall
Holland PA
2022 T@B 320S Boondock
TV: 2018 F150 -
I fixed the problem by adding a shutoff valve to the overflow line. I close it when I travel and leave it open all other times. Problem solved.
@Greenbean Can you please post a picture of your fix? How did you attach it to the overflow line?2022 T@B 320S Boondock
I no longer own the camper. I used a 1/2 inch ball valve and attached it to the overflow tube with a 1/2" pex crimp ring.
- 919 Introductions
