Thanks
qhumberd
Moderator
Thanks
qhumberd
Moderator
2018 Tab 400 not level during winterizing
Paul1959
Member Posts: 27
Hi all! I'm at it again-winterizing for my second year in a row. This time I did not have the trailer level for the process. Thought that I was OK with high side to the right, since LPDs are on the left. However, the tongue was high biasing the water to the rear of the system. Anyway, I am wondering if maybe I did not get all of the water out through the LPDs after I pumped out water from the faucets, etc... Would it be OK to open LPDs at this point and let AF(and residual water) out?
If you open your LPDs and a faucet, your plumbing lines will drain and you will need to repeat the process of running antifreeze through your lines. Chances are, you displaced any residual water with antifreeze, so why not just add more antifreeze to your fresh tank and open your taps again?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
Thanks Sharon! That is a good idea. I have plenty AF left, so I will do that.
- 916 Introductions
- 72 Teardrop Groups & Links
