alcohol free antifreeze/not available in my county
PaulKethley
Member Posts: 3
The ethanol free antifreeze does not exist in my area. Nucamp recommends a brand called Purf Century. Do I absolutely need this ethanol free antifreeze for my 2021 tab 400 boondock for winterization?
Ethanol is poisonous if you get some in you. You are pumping this stuff in your water lines… Your call, but personally, I wouldn’t use the stuff in my water system.
Poisonous, technically, but...most of us drink low concentrations of ethanol recreationally. It's isopropyl (rubbing alcohol) and methanol (wood alcohol / bad distilling byproduct) one usually might encounter and want to avoid.Denny16 said:Ethanol is poisonous if you get some in you. You are pumping this stuff in your water lines… Your call, but personally, I wouldn’t use the stuff in my water system.
@PaulKethley - the short answer here is 'no', you don't. The ethanol that's present in many brands of RV antifreeze will accelerate breakdown of rubber gaskets/seals, but it's not going to do so in a single season. I'd avoid if if possible, but if it's not an option, this is a 'something is better than nothing' situation. You might also look into the 'blowout' method (search here on the forums) as an alternative method for winterizing.
Northern VA
2022 T@b 320 S / 2021 Subaru Outback -
@PaulKethley, I assume you may be referring to this..
https://www.centurychemical.com/winter-pruf-antifreeze/
-Brian in Chester, Virginia
RV: 2018 T@B 320S, >100 mods -
How about this Prestone RV antifreeze..
RV/Waterline Antifreeze RVs, Pools, Boats and Seasonal Homes - 1 gal (-100° F) https://a.co/d/1BQaXJR
Says safe for water system components.
Cheaper at a local Walmart.-Brian in Chester, Virginia
- 919 Introductions
- 407 Service/Maintenance & Recall Notices
