Small Inverter Efficiency and Power Ports
Trailpixie
Member Posts: 191
I am using a small Bestek power inverter to run my laptop. The laptop power supply is rated at 90 watts on AC power. I calculated that it should pull an average of between 5 and 8 amps on 12v.
According to the smartshunt…
hmmm….. I wonder what the issue is?
I also wonder if a better inverter would get that consumption down closer to the expected-calculated-amperage numbers?
- When I plug into the electrical infrastructure I wired myself with 6 gauge wire from the battery to a wiring panel and then to a power port, it pulls 8-14 amps.
- When I plug into the original camper power port that uses 8 gauge wire from the battery into the camper, it uses 6-12 amps.
- bad power ports?
- bad wiring panel?
T@B 360 Black Canyon, 2021 Jeep Grand Cherokee V6, Maryland
(previous 2018, T@B 320 Outback)
90 watts should be 7.14 amps at 12.6 volts, allowing another 20% for efficiency loss and it should be around 8.5 amps.
It could be a less than desirable connection with the plug in, or another connection point issue. Does anything get warm after it is in use for a while?
I don't know which model you have exactly, but it appears that most of these are a "modified sine wave" VS a "pure sine wave".
Brad2020 400 BDL aka "Boonie"
Concord, NC
- 917 Introductions
- 73 Teardrop Groups & Links
