Atwood CO/LP Gas Alarm End of Life
Tabaz
Member Posts: 2,420
I just noticed my Atwood Propane/Gas detector had all lights blinking and is emitting two beeps every 40 seconds or so. This seemed unusual because the propane bottle is closed and there is plenty of air movement in the cabin. Found the manual online:
https://www.manualslib.com/manual/1224342/Atwood-Lpco.html#manual
Page 11 states the following:
End of Life Mode
End of Life Mode
The Detector will operate in end-of-life mode after the Detector has been powered
for 7 years +/- 128 days. This represents the operating life of the sensors used to
detect CO and LP gas.
After 7 years, the sensors are no longer reliable and the Detector must be replaced.
Once end-of-life mode has been entered, it is permanent, even after a power out
cycle.
My T@B build date is August 2015 (don't know the manufactured date of the Atwood). Time for a new detector. Brand new on eBay for $79.
2016 Outback 320
Let us know how easy or difficult the replacement install is. Hopefully the former!2021 T@b 400 BD "Vixen Gail"
Leadville Colorado0 -
I moved mine when putting the Lagun mount onto the lower seat panel. It was very easy to snip the wires and reattach in the new location. Replacing it should not be difficult.
I had to replace our stock sensor even though it wasn't near its expected life (2021 320S). We sleep in the twin bed setup and my head is right by the sensor. Last summer the thing started going off at random times (like 2:00 am, 3:00 am, 4:00 am) and man, that thing makes a racket!! Talk about a rude awakening!! We were on a 2 week trip and I just clipped one wire to shut the thing up so we could get some sleep. It was summer and we weren't using the propane for heat so I was fairly comfortable doing that to get by in the short term.
I replaced it with an "RV Safe" brand detector and the footprint was the same. Very easy replacement - clip the 2 wires and join them back up to the new one. Now I can get a good night's sleep.2021 320S BD
2017 F-150
Coeur d'Alene, Idaho0 -
Thanks for the heads-up @Tabaz . We've been through this with a CO/propane detector in our family room where we have a gas fireplace. Right on schedule, it went into the unstopable periodic chime at the lifespan limit. For anyone relocating their detector, make sure you place it close to the floor (NOT close to the ceiling like a smoke alarm, which rises due to heat), as these molecules are heavier than air.
Looks like we may be due for replacement in about a year or so.
PS: This safety feature is especially important to me since I lost my sense of smell about 7 years ago. Our outdoor grill had been leaking propane (switch got turned on by accident), and 4 other people smelled the gas odorant, but I could not. So, for me it's now like CO - odorless.-Brian in Chester, Virginia
RV: 2018 T@B 320S, >100 mods1 -
BrianZ - This is such an important safety device. I'm thankful the Atwood unit provided an unequivocal warning that the sensors were no longer operative. Kudos to them for incorporating this fail-safe feature in their product. For those with units seven years old, be proactive and replace your CO/LP detectors now.2016 Outback 320
2024 Ford F150 Supercrew short bed.2 -
WayneW - please provide the link for your replacement detector assuming the cost is less than $79 available on eBay.2016 Outback 320
Here is the link to the CO/LP detector that I bought to replace the Atwood. Currently $59 w free shipping. Be careful when looking because you often run into a detector that looks the same but only detects CO. Amazon currently has the CO-only model for about the same price as this one which is the carbon monoxide and propane model.2021 320S BD
2017 F-150
Coeur d'Alene, Idaho1 -
Bergger - VERY simple replacement. In my case, the two red wires are connected as one because there is no additional battery back-up from the factory. Took all of 10 minutes from start to finish.2016 Outback 320
Good to know!2021 T@b 400 BD "Vixen Gail"
Here is another option that I installed last June. $83.00 at Home Depot. The mounting screws are in a slightly different location. Otherwise, it's a direct replacement and fit in the original cutout. I did not get another Atwood as another thread here found that either the CO or LP detection did not work. I could not find the thread to reference.MTI Industries 45-742 Series Safe-T-Alert Dual Carbon Monoxide/Propane Alarm in White2016 T@B 320 M@X S "Annie", 3rd Owner
2015 Little Guy 5-Wide Platform
2015 MB GLK 250 (diesel) Tow Vehicle, "Benzie"
Sequim, WA USA2 -
yep, time to update
https://www.amazon.com/Monoxide-Propane-Detector-Replacement-Hardwired/dp/B0DFLZBQJLT@B 400 , Tundra0
