Connection leak on heater start-up
RollinWithShirley
Member Posts: 44
We are getting ready for winter travel and I started the heater to get the trailer warmed up. Within the first 30 minutes I noticed water dripping from the bottom of the trailer beneath the heater compartment. When I took a look, the coupling (?) on the cold water line into the Alde was leaking and seemed somewhat loose. I pushed it back together and it stopped leaking. The similar connection on the hot water to the Alde was not leaking but also seemed loose fitting. Is this something I need to address? Is it a DIY fix?
If I remember correctly, this coupling is simply a reducer connecting a larger to a smaller pipe. It seems like simply pushing it back together should work, but hopefully someone of plumbing authority will chime in😊Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
