If it is a newer T@b, yes.NeontaB said:My friend says I need a small charger like Deltran battery tender for winter storage. Reviews don't look so good.
Isn't the charger in my T@B able to maintain a battery while being stored? To just leave it plugged in?
Thanks
I plan to connect a UPS with surge protect and charge the battery one full day every 2 weeks while in storage. Hope this way it will keep the battery healthy.Mouseketab said:As long as you can keep it plugged in, you are good to go. The battery tenders are for times when you have no power for storage. Folks bring the battery home for the winter and put it on a trickle charge.
I put my batteries in my garage over the winter to keep them from freezing (NE Ohio) and put a 1 1/2 amp charger on them once a month. They take just a couple of hours to top off and they're good for another month.Playc said:I plan to connect a UPS with surge protect and charge the battery one full day every 2 weeks while in storage. Hope this way it will keep the battery healthy.Mouseketab said:As long as you can keep it plugged in, you are good to go. The battery tenders are for times when you have no power for storage. Folks bring the battery home for the winter and put it on a trickle charge.
Just not comfortable when not around to have TAB connect to AC all the time.
If you do not have the battery plugged in except for that one day every two weeks, you need to disconnect it from the T@B when not plugged in. Either by way of a disconnect switch or removing the negative lead. The T@B has parasitic drains that will kill your battery in two weeks time.Playc said:I plan to connect a UPS with surge protect and charge the battery one full day every 2 weeks while in storage. Hope this way it will keep the battery healthy.Mouseketab said:As long as you can keep it plugged in, you are good to go. The battery tenders are for times when you have no power for storage. Folks bring the battery home for the winter and put it on a trickle charge.
Float Mode: If the RV is not being used for approximately 48 hours, with a “no load” condition and the shore power is plugged in, the converter will automatically go into the “Float mode.” In this mode, the converter is charging the battery with a trickle voltage of 13.2 Vdc. When the converter senses a demand (by turning on lights), the converter automatically returns to the “Absorption mode” 13.6 Vdc.
Which one would you suggest to buy? Thanks.mash2 said:I second the delTran battery tenders. Mine has served me well since I picked it up a few years ago.
gilbutler said:From Page 5 of my WFCO manual:Float Mode: If the RV is not being used for approximately 48 hours, with a “no load” condition and the shore power is plugged in, the converter will automatically go into the “Float mode.” In this mode, the converter is charging the battery with a trickle voltage of 13.2 Vdc. When the converter senses a demand (by turning on lights), the converter automatically returns to the “Absorption mode” 13.6 Vdc.
Thanks for the info. Are you saying that I can have AC 110 plug in all the time during storage and no need for any additional purchase like DelTran?
Playc said:gilbutler said:From Page 5 of my WFCO manual:Float Mode: If the RV is not being used for approximately 48 hours, with a “no load” condition and the shore power is plugged in, the converter will automatically go into the “Float mode.” In this mode, the converter is charging the battery with a trickle voltage of 13.2 Vdc. When the converter senses a demand (by turning on lights), the converter automatically returns to the “Absorption mode” 13.6 Vdc.
