I just purchased a 2015 t@b -cs model in May. I have used it several times with no problem. I have used the hot water several times, both when hooked up to water and when using the holding tank. However last time I used it, I had no hot water. The fuses appear to be ok. Any suggestions? Thanks!
0 ·
To follow PXL's thought, did the Alde work otherwise, ie: do the heating coils get hot under the seat when you turn on the heating system?
What are your controls set to?
I've never actually looked for that one.
I think it is the same fuse as the Eaton Manufacturer part # BK/S500-3.15-R.
I found it at Mouser Electronics. Here is another link to the specific one you indicated (I have a DM so haven't needed).
http://www.mouser.com/ProductDetail/Bussmann-Eaton/BK-S500-315-R/?qs=sGAEpiMZZMsIz3CjQ1xegR8PufwtdR8uDWW5JByr0JY=
Gil
