Removal of tree sap
Jetman
Jetman Member Posts: 45
edited February 2023 in Tips & Tricks
can anyone tell me what to use to remove hard, dried tree sap on the roof panel of my 400?
Thanks
DD
  • Jetman
    What is the best wax to use on the aluminum panels ( top and sides) of the TAB 400
  • Tabinator
    Tabinator Member Posts: 33
    Hi there.  Scrolling thru the forum and found your question.  I use hand sanitizer to remove sap. Place a drop of sanitizer on, rub in a bit with a finger, wait about 30 seconds for the sap to melt, then wipe with a soft cloth.  Repeat if necessary.
    2018 T@B 400 in the company of 2009 Ford Flex 2023 F150 Powerboost
  • rfuss928
    rfuss928 Member Posts: 1,197
    edited April 2023
    Goo Gone is a citrus based cleaner that works well and is quite harmless to the finishes and windows on our T@Bs.  On dry sticky sap let it soak for a bit.  On vertical surfaces, soak a small piece of paper towel and stick to the effected spot to keep cleaner on it for a bit - even overnight.
  • Jetman
    Thanks for this info I will try it next time. This sap was very old and hard.I bought a plastic sheet rock scraper and chipped the majority off and then soaked in rubbing alcohol and rubbed hard with a micro fiber cloth. Fortunately no scratches in the paint.
  • ybakos
    ybakos Member Posts: 60
    Just use simple rubbing alcohol (hand sanitizer will indeed work, too). The alcohol will dissolve it almost immediately and it'll wipe right off. If the sap is super hard, just let it soak for a minute and use a little elbow grease.
    2022 Tab 320 CS-S Boondock
  • cpinkerton
    cpinkerton Member Posts: 1
    Without question rubbing alcohol worked well and worked the best. I tried a number of solvents for pine sap including acetone, Coleman fuel (white gas), Goo Gone, mineral spirits.
  • sportcoupe
    sportcoupe Member Posts: 30
    I use plastic razor blades.
    100OR Orange Plastic Double Edge General Purpose - 100 Blades  The Razor  Blade Company
    2023 T@B 320 S BD,
    TV: 2023 Ford Bronco 2.7L Wildtrak 4x4, Tow Package, Ford Brake Controller
    Georgia
  • bergger
    Rubbing alcohol does work very well but be cautious as it can take off a paint finish and you will be able to see those blemishes.  I found this out by using it on my wife's car!  The good news is that it is much less visible on lighter finishes like silver and white.
    2021 T@b 400 BD  "Vixen Gail"
    Leadville Colorado
