De Winterizing 2022 TAB 320S Boondock
Playa_Bonita_30A
Member Posts: 22
I started the de winterizing process today by draining via the exit drains
In this order I opened the fresh water tank, the gray water tank, then I opened, I believe the drain value on the right next to the gray valve. The antifreeze shot out with force all over me. I then expected the same on the valve on the right, but nothing came out at all.
I am positive I followed the winterizing process correctly and I turned on both hot and cold at the faucets
is this normal? Did I do something wrong?
I am praying I don’t have a link now as a result of a frozen pipe
i plan to run the water to clean out the pipes tomorrow
thanks again for your help here
Does antifreeze enter the hot and cold lines regardless if you turn the faucet to hot? I know I turned all the faucets to hot and cold multiple times - just lost as to why no solution came out of the second exit valve.
Pictures really help us help you.
Here are some photos from Scott14. Not sure which drain valve on the right that you are referring to?
Here are some instructions that I created for the TaBs with Nautilus: https://tab-rv.vanillacommunity.com/discussion/8904/dewinterizing-and-sanitizing#latestSharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
- 919 Introductions
