Thanks
qhumberd
Moderator
De Winterizing 2022 TAB 320S Boondock
I started the de winterizing process today by draining via the exit drains
In this order I opened the fresh water tank, the gray water tank, then I opened, I believe the drain value on the right next to the gray valve. The antifreeze shot out with force all over me. I then expected the same on the valve on the right, but nothing came out at all.
I am positive I followed the winterizing process correctly and I turned on both hot and cold at the faucets
is this normal?  Did I do something wrong?
I am praying I don’t have a link now as a result of a frozen pipe
i plan to run the water to clean out the pipes tomorrow
thanks again for your help here
