Are you referring to the 7-Pin Cable Junction Box mounted on frame?
The cover is held in place by two large Phillips or Hex Head bolts . . . at least that was the case up to model year 2019 . . .
The Bolts are at the Red X positions on the cover:
How to open trailer J box
Yoshi_TAB
Member Posts: 592
Hi,
I'm looking for some hints on how to open the trailer junction box. I've done a minor re-wiring effort to install an inverter and lithium batteries inside and I want to confirm the #6 pin in the box is getting power.
I can feel (although I can't see it) that there is a tab on top of the j box that maybe you press. But before I go and and possibly not do it right (i.e break it) , I thought I'd check with others.
Thank you
Thank you
2025 360 CS
Southern Maryland
Southern Maryland
Hi,
Yes, that's them. I see them now, they are recessed below flush and did not see them w/o a flashlight.
Just curious, is there any sealant or rubber gasket between the cover and the box?
Thank you,2025 360 CS
Southern Maryland1 -
There might be a gasket in the cover, but I don't recall for certain. Either way, I've never had an issue removing and reinstalling the cover. There is nothing you have to clean off or replace.
2015 Nissan Frontier SV V6 4x41
