Sure that this has been discussed, but not having luck searching.
With my AGM's, I had the Battery Preset set to "User Defined" with Absorption @ 14.6V and Float @ 13.6V per the battery manufacturer specs.
Digging around in the Victron app I found the "Smart Lithium (LiFePO4)" setting. When selected it changed my Absorption to 14.2V and Float to 13.5V.
Is this the setting that others use or is there a User Defined setting that's preferred?
https://battlebornbatteries.com/programming-a-victron-smartsolar-charge-controller/
Battle Born recommends using the User Defined setting with the absorption voltage at 4.6 volts (acceptable range of 14.4 to 14.6 volts). Makes me question if this is something unique to the Battle Born batteries. The default Victron lithium setting is 14.2V and the spec sheet for my battery that I posted above has the Boost Charge Voltage also at 14.2. Seems strange that it's not even in the "acceptable range" for Battle Born.
I'm curious what others with non Battle Born batteries are doing. Is using the Smart Lithium Battery Preset something commonly done?
You may have seen this at the bottom of the link, but here are the settings for Lion batteries starting on page 4 for the solar controller. Their settings are somewhat different. Battery and Solar Resources (vanillacommunity.com). Not sure this is helpful other than more info to get confused about (speaking for myself
Southern Maryland
edit to add that it's odd that Battle Born's acceptable absorption range of 14.4 to 14.6 volts is far below the 13.9V that you're using for your Lion Safari UT batteries.
