Quiet water pump
2018 Tab 400.
Just installed a Lippert flow max pump to replace a Shurflo that had lousy pressure. New pump has good pressure but is EXTREMELY LOUD. Any recommendations? Thanks
  • Mickerly
    Mickerly Member Posts: 518
    The standard, Shurflo, pump mounts to a soft, think rubber mount to isolate sound. How is the new pump mounted?
    2018 320CS-S
    "Just Enough"
  • AndreO
    AndreO Member Posts: 88
    Check out IRVWPC pump controller.
    I put one in on my 2018 400 and it really reduces the noise. Easy to install and does take up the whole compartment.
    AndreO
    Ontario, Canada
    2018 Tab 400
    Ford F150 2.7 Lariat
  • crowsnest
    crowsnest Member Posts: 50
    Installed Valterra water pump silencing kit (two long hoses). Makes a big difference. Also fixed low pressure problems. As noted by another member drill shavings from manufacturing of water tank end up clogging the line between tank and filter. Clear the line and presto! Shouldn’t NuCamp dealt with this before selling the trailer?
  • StepheninDen
    StepheninDen Member Posts: 56
    edited May 2023
    I added a SeaFlo accumulator tank to my ShurFlo pump. Cut the noise in half. Might cushion the pex pipes next but it’s so much better that I’m not sure it’s needed. Added benefit is the pressurized tank lets water flow smoothly instead of pulsing.
  • Robermcm
    Robermcm Member Posts: 96
    You have any pictures of how that fit?
    2026 Haven
    2023 Tab 400 - sold
    2015 Audi Q7 TDI
    Northern Ohio
  • rfuss928
    rfuss928 Member Posts: 1,197
    This is my accumulator install in the sink cabinet.  It made a tremendous difference in my 2009 CS.  I don't seem to need one in my 2023 CSS.
