Just installed a Lippert flow max pump to replace a Shurflo that had lousy pressure. New pump has good pressure but is EXTREMELY LOUD. Any recommendations? Thanks
Installed Valterra water pump silencing kit (two long hoses). Makes a big difference. Also fixed low pressure problems. As noted by another member drill shavings from manufacturing of water tank end up clogging the line between tank and filter. Clear the line and presto! Shouldn’t NuCamp dealt with this before selling the trailer?
I added a SeaFlo accumulator tank to my ShurFlo pump. Cut the noise in half. Might cushion the pex pipes next but it’s so much better that I’m not sure it’s needed. Added benefit is the pressurized tank lets water flow smoothly instead of pulsing.
You have any pictures of how that fit?
2026 Haven
2023 Tab 400 - sold 2015 Audi Q7 TDI Northern Ohio
"Just Enough"
Ontario, Canada
2018 Tab 400
Ford F150 2.7 Lariat
2015 Audi Q7 TDI
Northern Ohio
