Valve on fresh water overflow pipe?
In one of those wonderful dump station conversations (ahem), a fellow RVer recommended adding a valve to the fresh water overflow pipe suggesting that if you close it you while you're trundling down the highway, you would lose a lot less water from a full tank. Seemed like a reasonable idea, you just have to remember to open it at the campsite. It's an easy enough modification, but as I was digging through my irrigation supplies to see if I had what I needed, a couple thoughts came to mind.
First, do you really lose enough water to necessitate such a thing? Second, I'd be a tiny bit concerned about expansion due to heat; i.e., would that extra pressure in the tank cause short- or long-term problems?
Thoughts or comments are appreciated...
— Richard R.
Front Range of Colorado
2023 TAB 400 Boondock
2022 GMC Canyon
2023 F150 Hybrid (PowerBoost drivetrain)
  • AndreO
    AndreO Member Posts: 81
    What trailer and year do you have? On a 400 the overflow  pipe is well above the water tank. I doubt even one drop is lost to sloshing etc.
    AndreO
    Ontario, Canada
    2018 Tab 400
    Ford F150 2.7 Lariat
  • Richard_R
    Richard_R Member Posts: 40
    2023 TAB 400 boondock
    — Richard R.
    2022 GMC Canyon
  • KK1L
    KK1L Member Posts: 117
    And when you forget to open the valve when filling...and you will...what then? I have filled fresh to overflow as a habit in my campers, but I don't know if anything gets lost enroute. I might say you could give it a try and let us know :) My guess is it is not worth worrying about or worse setting yourself up for a potential problem. Certainly the time spent on the experiment below is not worth the time. Unless you have a YouTube channel and need an idea for an episode.
    1. fill to overflowing
    2. empty and measure the volume
    3. fill to overflowing
    4. drive around
    5. empty and measure the volume
    6. subtract 2 and 5
    7. report the loss
    73 es God Bless de KK1L, Ron <><
    2023 T@B 400 Boondock "Running up a T@B"
    Jericho, VT
  • Richard_R
    Thanks for the input @KK1L, but I think I'll decline on your experiment  ;) . In fact, I've already decided to abandon the whole project...
    — Richard R.
    2022 GMC Canyon
  • rfuss928
    rfuss928 Member Posts: 1,181
    edited June 2023
    4. drive around
    6. subtract 2 and 5
    7. report the loss
    OR
    1. Fill to overflow
    2. Mount GoPro camera facing overflow outlet
    3. Start camera
    4. Go for a ride
    More and better video for your YouTube....
