Pump switch on all the time or only when needed?
ybakos
Member Posts: 60
Once you're at the camp site, do you turn the pump switch on and leave it on? Or do you turn it off at night or when you know you won't be using water for an extended period of time?
2022 Tab 320 CS-S Boondock
I'm guilty of leaving it on but most people prefer to turn it off when they are away from the trailer in case something springs a leak. The pump will happily flood the trailer.1
I personally leave it on when I am at the campsite, including overnight. I do turn it off whenever we leave for any length of time.--Marlee
2021 Tab400 Boondock; TV 2025 Jeep Grand Cherokee Limited; Minnesota0 -
If boondocking, only on as needed. If plugged in, off at night & when away from trailer.2019 320s BD Lite, white with blue (“Haven”)
Pacific NW0 -
ON overnight for the toilet
OFF the rest of the time unless we need it2022 T@B 320S Boondock
2021 Toyota RAV4 TRD Off Road
Ottawa, Ontario, Canada
Instagram: new.t@bventure0 -
On/off as needed.0
On only as needed when boondocking. Otherwise it's on all of the time unless we are away from camp.
2021 T@B 320CSS Boondock - "Chirping Bird"2018 Chevy Colorado - "Dad's Truck"0 -
As needed, just in case...0
If you turn it on, it will run only when the pressure is low. Assuming you have no leaks, it will only run when needed. If you have a leak, it will pump until you are out of water....
I turn ours off when not needed. My wife turns it back on. The choice is yours.2018 320CS-S
"Just Enough"1 -
The issue with leaving the water pump on all the time, is if you spring a leak, you could flood the trailer. The water pump,in the TaB is a marine type pump, rated for intermittent use. So leaving the pump off until it is needed is the safest way to go. It on,y takes a few seconds to pump up pressure.
Always off if we leave the campsite.2021 400 BD
2020 Tacoma TRD Off-Road1 -
At a minimum for us, we turn it off at night since the switch light is so bright in the dark trailer.Rich2019 T@b 400
I use it only when needed. If you run it just before bedtime it will have plenty of pressure for a few flushes during the night without running it and waking your partner. Always a good idea!2018 T@B 400, 2015 F150 tow vehicle.0
Only when needed and never when I'm away from the camper but I will leave it on while I'm there once in a while. If it comes on and I'm not running water then I know to look for a leak.2021 T@B 320 S Boondock
2025 KZ Sportsmen 130RD
2025 Ford Ranger
The Finger Lakes of New York1
