Charging Battery
Can I charge my 12v 100 amph lithium iron phosphate battery with a battery charger (compatible with battery) while the battery is hooked up and powering my rv?
  • HoriganHorigan Member Posts: 852
    Yes.  Chargers are typically connected in parallel with battery loads.
    Rich
    2019 T@b 400
    Bellingham WA
  • AnOldURAnOldUR Member Posts: 1,698
    edited June 2023
    Not an expert, but I’d think a smart charger would be thrown off by power coming in from the converter and not charge to its potential.i
    edit to say that I misread the post. Sorry for the confusion.
  • techietabtechietab Member Posts: 161
    edited June 2023
    In the use case that @rmcarthur described, there isn't any power coming in from the WFCO converter. The charger will supply the 12v load drawn by the WFCO and any excess ends up in the battery. This is a typical use case with solar, AC mains or generator input to an AC charger. I was once 'boondocking' in an off-grid campsite close enough to our neighbor to run an extension cable over to the 20A outlet on their 50/30/20A power hookup to connect my Victron IP22 to their 20A outlet (they were only using the 30A outlet), and the IP22 happily supplied sufficient power for our 12V draw and kept the batteries hovering around 100% capacity.
    Additionally, when arriving home after boondocking with low-ish battery levels, hooking up both the 30A input to the WFCO plus 20A to my IP22 for my batteries resulted in nothing other than my batteries charging more quickly than usual. In fact, this is my usual approach to battery charging before leaving home, since my 'auto' select WFCO power center seems to always somehow knock itself out of Lithium mode and fails to adequately charge my 2x 100Ah LiFePo4 batteries.
    Northern VA
    2022 T@b 320 S / 2021 Subaru Outback
  • rmcarthurrmcarthur Member Posts: 51
    Thanks for the info. I'll hook it up and monitor the progress.
