Easy Fan Replacement
Basil48192
Member Posts: 437
I have read multiple posts on this forum about upgrading the Fantastic Fan...but there are so many discussions that my eyes begin to glaze over after a while.
I know that (if I can find one) I can install an upgrade kit to my fan which will provide multiple speeds and a rain sensor. But is there an upgrade out there that would replace the entire fan (blade, motor, controls) without having to remove the flange from the top of the T@B? I apologize if this has bee covered before. I don't mind doing the work, but I fear denting and/or compromising the roof. Thank you in advance.
I did the one referenced below. All I had to do was swap out the speed controller. I keep the existing fan, blades, etc. In particular I did the mod referenced by @Lloyd with a part purchase from Amazon.
https://tab-rv.vanillacommunity.com/discussion/7200/variable-speed-pwm-ceiling-fan-mod-10-bucks/p4
- 919 Introductions
- 405 Service/Maintenance & Recall Notices
