DC power oddments
Tross2023
Member Posts: 79
So the DC cig lighter works in both outlets by sink, and drivers side rear under the hutch.
the USB ports do not work.
I double checked all grounds, and all fuses on the fuse side of the electrical center thingy.
Everything on the wire bus on the floor behind the electrical thingy are tight.
I added a NEW ground inside the battery area from the neg battery pole to the steel frame of the red
plastic thingy
open to suggestions...
The extra ground goes from the negative post on the battery to the frame of the red thingy, it is steel, I checked it w/ a magnet.
plastic thingy
2024 Hyundai Santa Cruz and 2018 T@B 320S
The USB ports are a weak link. Best to replace them with a beefy 12V outlet and use a USB adapter. The solo USB outlets draw phantom power.https://tab-rv.vanillacommunity.com/search?Search=Replace+USB+
Lots of different Threads about the USB Port Failing.
They just aren't very high quality . . . do some Forum Searches and plan on replacing them . . .'18 320 S, pitched axle, 3020HE; PNW based
Thanks to all, I have been looking at upgrading my 120v AC outlets with USB in them. Still DC is ODD2024 Hyundai Santa Cruz and 2018 T@B 320S1
The USB cable ports are nice, but many owners have passed them by with simple 12V ports and car charging adapters.
Towed by 2014 Touareg TDi1
