Just replaced the two 6v AGM with Li, are old batteries worth anything?
d_v
d_v Member Posts: 42
I just replaced the two Harris 6v AGM batteries. They are from a 2021 T@b 400. Are they worth anything? What did you do with yours if you changed to Lithium?
  • rh5555
    rh5555 Member Posts: 540
    They might be of interest to other TAB owners who haven't upgraded to lithium.  Due to weight, shipping is likely to prohibitively expensive, so you'll be looking for a local who can pick them up.  Where are you located?
  • d_v
    San Antonio, TX.
  • AnOldUR
    AnOldUR Member Posts: 1,759
    When I switch out my two AGM's with lithium, I bought an inverter charger and used the batteries to run my sump pump if the power goes out at home while I'm gone.
  • fwunder
    fwunder Member Posts: 71
    Got a Golf Course/Country Club nearby?
  • rfuss928
    rfuss928 Member Posts: 1,192
    edited August 2023
    Battery recyclers pay $15 - $20 for auto batteries for the lead content.  Generally determined by weight or size.  The Interstate distributer in our area is always accepting any LA batteries of any type.
  • d_v
    Is that where these are used the most? I searched for the brand and model number and could not even find a retailer for them.
  • Maxcamp
    Maxcamp Member Posts: 352
    edited August 2023
    I find my old camper battery invaluable as a portable 12v power source.  Others do as well and run or charges devices, fridges, etc.  Helpful for testing various trailers' ebrakes and lights.
  • SLJ
    SLJ Member Posts: 663
    Sold my two year old 100AH AGM on marketplace for $100 bucks. There's also a battery place near me that buys dead ones.
    2021 T@B 320 S Boondock
    2025 KZ Sportsmen 130RD
    2025 Ford Ranger
    The Finger Lakes of New York
    pthomas745 Administrator, Moderator Posts: 4,686
    I used my "old" 80 amp hour stock battery as a "spare" for  a few trips before it gave up the ghost and slowly failed.  Like Maxcamp said, I used it for a portable 12V fridge, and it worked very well for that.  The dual 6v setup can probably be used for that sort of purpose, except...they just weigh so much.
    Unless the 6V batteries had been changed from stock, they were originally Harris 6V, you might find some info here on the models.  The 6V battery has been called the "golf cart" size for ages.
