Progressive Industries EMS-HW30C: A delay in providing power is how it works…
Hi All,
I found out some interesting information today as I was prepping for a camping trip in a couple of weeks.   I noticed that when the camper was first plugged and going through the EMS no AC or DC was working for approximately 2 min 15 sec after plugging the camper into a 20 amp home circuit.  I measured twice.   I thought the converter was a problem.   However, when I used the pass through option on the EMS, the converter immediately went on.   I contacted tech support at Progressive Industries and they explained that it takes 2 min 16 seconds before power comes through the unit.   What a relief and the tech was quite generous in explaining that and more.   I learned there is a means of changing it to 15 seconds by opening the EMS unit and attaching a coupler.  I was so pleased to know everything was working as it should that I didn’t pay close attention to his “how to” discussion.   This is just one of those things that was either not in the manual or that was and I had forgotten about it.   Note, that when the power comes through to the converter you may hear a pop if there is anything drawing power.
Happy Camping!
2017 T@B 320 Q Max
2018 Toyota Highlander, XLE
Wisconsin
  • SLJ
    SLJ Member Posts: 666
    The older Progressive pole one I had on my motorhome took about three minutes. The newer hardwired I installed in my 2021 T@B is 15 seconds out of the box. It shouldn't be instant as it needs to make sure the power is steady.
    2021 T@B 320 S Boondock
    2025 KZ Sportsmen 130RD
    2025 Ford Ranger
    The Finger Lakes of New York
    Our portable Progressive EMS has an audible click as well.
  • AnOldUR
    AnOldUR Member Posts: 1,759
    I contacted tech support at Progressive Industries and they explained that it takes 2 min 16 seconds before power comes through the unit.   ...  I learned there is a means of changing it to 15 seconds by opening the EMS unit and attaching a coupler.
    Did they mention any advantage to the longer delay? Does it provide better diagnostics?
  • SLJ
    Would be no change in the diagnostics, just a longer sample time before allowing power to pass.
    2025 Ford Ranger
  • MadCityJack
    MadCityJack Member Posts: 110
    They did not say it made any difference.
    2017 T@B 320 Q Max
    Wisconsin
