Looking for advice!
Looking to purchase a Nucamp T@B 320. Found a 2018 Tab 320 and when inquiring with the owner about last time Alde system was flushed he indicated it has never been flushed since he purchased it in 2019. How concerned should I be? Will non-maintenance cause inoperability or system issues that would be costly to repair?
Owner says they have only used unit 8-10 times since they purchased it. Unit is priced good and looks good. Priced a couple thousand below what others are asking. Would have to travel a couple of hours to transact deal.
I’m not handy and any repairs would have to be done at service system.
Is it worth gambling on.
Thanks
DZ
thanks
Time will tell for us, but just take care of it after you buy it. You have an honest seller. See if it works now heating water and providing heat. Decide after that. Also, we agree with @AnOldUR and that should do it for you.
2019 T@B 400 BL
2021 Toyota Sequoia 4WD
thanks for your replies. I do appreciate it. I’ve got a couple hours drive tomorrow and wandering if it’s a big deal or not to overcome. And how much added expense it could be.
Here's an example of a bad one, but it could be even worse ...
FYI - I called Alde and spoke with a rep and he said the glycol will crystallize over time and cause etching in the tubing? Not sure exactly what that means.
It's very similar to a car and having to do more frequent maintenance on a car that is heated and cooled over and over, but never brought up to operating temperature and allowed to burn off moisture within the oil and other fluids.
Southern Maryland
