Awning Parts
We are making a eyebrow type awning, anybody know where to get the curved metal frame?
Thanks
tom
2024 Hyundai Santa Cruz and 2018 T@B 320S
    Check out Tent Pole Technologies. They can custom build just about anything according to your specs. I purchased replacement sections for my PahaQue awning pole a few years back. IIRC, prices and shipping were both very reasonable.
  • Tabaz
    Tabaz Member Posts: 2,420
    I strongly suggest getting a metal pole - not fiberglass.  One of the best mods I ever did was replace the fiberglass pole in my XL Visor with metal.  Bought the metal pole sections on Amazon for about $24.  You will need a longer length because its going to be an awning.  Would be happy to measure my PahaQue awning pole for you.
    2016 Outback 320
  • Homebodyatheart
    @Tross2023 I also bought an aluminum pole for my visor and have no regrets. I believe that I needed 19’ of pole, so I bought a two pack off Amazon and added the necessary sections from one to the other, cutting the last section down to get the correct length.
  • Tross2023
    Tross2023 Member Posts: 79
    thanks to all, having trouble commenting today
  • Tabaz
    edited March 2024
    Hope you're having a better day today.
    2016 Outback 320
  • Ronb67
    Ronb67 Member Posts: 5
    My awning took a beating during a storm last weekend.  Three of my aluminum poles are pretty well shot. Does anyone know where I could check to replace them?
    Tent Pole Technology. https://www.tentpoletech.com/
  • Horigan
    Horigan Member Posts: 925
    The weak points are typically the smaller diameter short connector tubes, not the longer pre-bent tubes.  If those are the areas that are bent, a good hardware store sells the correct diameter tubing.  That and the correct size drill bit and you can replace the connector tubes.  I think it's key to maintain the gap between the longer tube ends when you make them so they have room to bend in the next wind storm.
    Rich
    2019 T@b 400
    Bellingham WA
