Alde fuse continues to blow.
Jeanne
Jeanne Posts: 65
I read somewhere that on the 2014 T@B the factory has found problems with the Alde. Ours works fine until I turn it off, then that's it until I replace the fuse and it is always the same fuse. Suggestions?
2014 T@B S Max, TV 2012 Jeep Grand Cherokee Overland Summit, Richland, WA
  • jkjenn
    jkjenn Posts: 6,424
    I have not heard of any reoccurring problems with the Alde. I would either call Alde or ask the factory to replace it.
    Here is a shot in the dark, though, any chance you slide the slider all of the way to the left on the Alde panel (shore power - lightning bolts) to the top while using either 120v power or 15 amp?
  • ChanW
    ChanW Posts: 3,165
    Jeanne, yes, warren207 was talking about the Alde fuse problem here: http://tab-rv.vanillaforums.com/discussion/comment/18436/#Comment_18436
  • Will contact the company and keep looking for the thread I read recently. Doesn't appear to be a voltage problem because happened this weekend while using propane.
    Thanks ChanW for the link.
