Axle question
redaunt
Member Posts: 31
We are possibly interested in upgrading from our T@b 320 Outback (2017) to a used T@b 400. We went and looked at a new T@b 400 today at a local dealer. Husband thinks the axle is not as “heavy duty” as the axle on our older T@b. Does anyone know if the axle in the T@b 400 is less “beefy” than the older T@bs?
The Outbacks have different axles with higher lift. These are torsion axles and the Outbacks are set at a different angle. Maybe that's what he's referring to. Unaware of any other differences, other than maybe higher load rating for the 400 axles.
Rich2019 T@b 400
They are all Dexter axles. The Outback probably sits higher due to tires. Check the tires on the t@b 400 - they come with some Chinese imported off road looking tire that while they look great, if you have a problem on the road you are out of luck finding a replacement. Only source we could find was ordering one through nuCamp, so we went with Goodyear Endurance, which are a size smaller.
Haven 220
2026 Ford F150 Tremor 5.0
Niceville, Florida
