Getting Rid of the Hum or Buzz from the Speakers
jkjenn
Member Posts: 6,425
This is one of the those tasks that could/should have been done a while ago, but just was put off. I was getting a quiet hum from the speakers any time they were on but it was worse if I ran the fan for had lights on. It was really bad if using the HDMI input on the TV. @Michigan_Mikehad suggested a noise isolator when neither Jensen or the factory could help me. I used the Boss Audio B25N Ground Loop Isolator Noise Filter. It was completely simple to install- less than 5 minutes and it completely removed the hum.
To install it:
Unscrew the 4 square-headed screws with a #1 square screwdriver. The screws fall out and are easy to loose so be careful. You could put tape over the holes where they are recessed if you want to be extra careful.
1. Carefully, pull the Jensen head unit from the cabinet.
2. Unplug the red and white cables from the rear of the Jensen unit.
3. Plug the red and white cables into the female cables on the Boss unit.
4. Plug the male red and white cables from the Boss unit into the corresponding jacks in the rear of the Jensen unit.
5. Replace Jensen unit into the cabinet.
6. Reseat the four square screws.
To install it:
2
