Adding Solar Panels
Rickman52
Member Posts: 3
Hey Folks, I have a 2022 Tab 320S that already has a solar panel on top, I am looking at the Renogy 200 Watt solar panels with 20 amp controller. I have a 100ah Renogy 100AH AGM Battery. Is it safe to hook this up to the Battery? Thanks, Rick
Yes, it is fine to have 2 sources of solar. It will charge faster. 300 AH solar will future proof your camper for a larger battery, too.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Hi,
Yes that would be safe to add additional solar panels wired in parallel. Some good practices are;
-use busbars rather than having multiple connections on each battery post.
-locate the solar charge controller as close to the battery as your set up allows to maximize charge current from the portable solar panel
-use fuse protection and wiring sized for your circuit.2025 360 CS
Southern Maryland1 -
Agreed. I did the same thing, however I bypassed the controller on the Renogy 200w panel and added a second Victron controller inside the tub. I often camp on state land deep in the woods and have to move my suitcase panel around to catch the sun. So, as @Yoshi_TAB mentioned, I wanted the controller as close to the battery as possible. Also, I really like the Bluetooth convenience of the Victron controllers.
I also used a bus-bar as mentioned above. You can see it in the photo below, just to the left of my battery monitor shunt.
Good luck!
@Rickman52 - are you referring to a solar suitcase or installed?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
