Use of Alde after Winterizing
KandD
KandD Posts: 5
We have winterized our T@B S Maxx (2015) because it could get cold here anytime.  We still want to camp and we are wondering if we can use the Alde for heat eventhough we will not be using water.
  • Nomad
    Nomad Posts: 7,209
    I did for the whole month of Nov last year before I got south enough to dewinterize again.
  • So you used your Alde without being connected to water and without having any water in your Alde?
  • ChanW
    ChanW Posts: 3,165
    Yes you can use the Alde in the winter.
    There's a specific way to winterize your plumbing to keep the winterizing antifreeze out of the Alde.
    It's been discussed here. Do a search for "bypass" here on the forum.
  • Wonderful. Thanks PXLated and ChanW.  When my husband did the winterizing he did it so no antifreeze went into the Alde.  Thanks so much for the information! We should be all set.
  • Nomad
    Nomad Posts: 7,209
    The Alde (in essence) as two systems...
    1) The heating system which uses heated glycol (not water) to heat the T@B - it's a somewhat closed/sealed system other than the overflow container that allows you to top off the glycol if necessary. This is the half that feeds the radiators
    2) The hot water system - this is a small chamber that preheats a limited amount of hot water and then provides the on demand hot water
    You never drain/winterize #1, it won't freeze up, it's glycol.
    You do drain and winterize #2 as it's water
    The plumbing for the two are independent of each other.
  • Sgtjohn
    Sgtjohn Posts: 238
    I didn't find glycol at the T@B Store awhile back, can it be found at AutoZone, HD etc?  I know regular antifreeze is bad for the aluminum.
  • Nomad
    Nomad Posts: 7,209
    Ya, you can have heat - Even without shore power - I carried bottled water for cooking, drinking, etc. Alde on propane/battery - solar to recharge the battery.  Spent a month before I got south enough to dewinterize and refill the onboard water.
  • ChanW
    ChanW Posts: 3,165
    That's one of the best things about this darn cute little camper. How easily it goes off-grid.
    I like the fact that LG added isolation valves to the water system for winterizing the Alde, although I prefer the blow-out method, rather than using antifreeze.
    The one time I used antifreeze to winterize, it took five rinsings or more to get it out in the spring.
  • jkjenn
    jkjenn Posts: 6,424
    I just did a search for the Sierra Peak and it appears that in my area, Dollar General, and Advanced Auto Parts,
  • Photomom
    Photomom Posts: 2,217
    This reminds me of a couple things I've been wondering about.
    1. What do you do with the antifreeze when you remove it in the spring?
    2. Is it possible to use either a manual bike pump or a tire inflator to "blow" out the system, or do you need an air compressor?
  • Nomad
    Nomad Posts: 7,209
    Photomom - Bike pump = Hand pump? What do you mean by "tire inflator"?
    I'm the ChanW camp, use the blowout method. I use what I would call a "tire inflator" - Small, portable compressor that clips to a battery. There was a thread last fall that talked about what was needed as far as blowout pressure - based on that, I bought the portable compressor.
  • jdargis
    jdargis Posts: 305
    Standard floor bicycle pump w/gauge works well, blowing out the water lines.  The lines are so short, compared to a motorhome or large trailer.  Pump the bike pump to 40 psi and release water through faucet, etc. Continue, until just air discharges.
  • jkjenn
    jkjenn Posts: 6,424
    edited September 2015
    I used a bike pump until I got the right attachment for the compressor. Regardless of the method, You need a blowout plug. I have a portable compressor that I cannot use as it is 125psi. You should not exceed 50 psi on your compressor.
  • Photomom
    A tire inflator is one of these things: http://www.amazon.com/Black-Decker-ASI300-120-Volt-Inflator/dp/B000IE0YIQ/ref=sr_1_10?ie=UTF8&qid=1442622244&sr=8-10&keywords=tire+inflator
    We take one camping for bike tires, tires on the boat trailer, etc.
  • Photomom
    So, what do you do with the used RV antifreeze? Do you need to take it to haz mat collection?
  • jkjenn
    jkjenn Posts: 6,424
    RV antifreeze is non-toxic and safe to flush with grey water.
  • jkjenn
    jkjenn Posts: 6,424
    FYI, if you have a portable compressor like mine, that is more than 50 psi and not adjustable, you can use the same pressure regulator you use on your water hose. I use this air compressor because I air down my Jeep tires when I go off road. It fills the tires at a decent rate and feel that it is a good value. You can get higher powered compressors, and ones that actually are mounted in your TV, but this one suits my needs.
