Water leak
R3rohde
Member Posts: 1
We discovered a small amount of hot water under the sink in our 2016 CS-S. We cannot determine the source. Could it be the coupler on the hot water tubing or from the Alde system? TIA for any insight.
Try this thread, if you think this might be a mixing valve issue or maybe a leak at the "John Guest" adapter fitting under the valve. Is this the area you think the leak might be coming from? The thread linked in the comments go to a discussion of the fittings, etc.
Check the hot water supply hose to the sink. We had a bad crimp on our 2017 CSS. Easy to replace. Where was it found? The floor of the cabinet, a shelf, where?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
