Want to replace heavy table with Lagun-- help please
lkc001
Member Posts: 881
I have a 2018 Tab 400-- which has the really heavy table & I can't deal with it. Have read old posts--Verna's post & Geo Montana post on putting in a Laguna table & the support structure added to the panel that covers Alde stuff.
I removed the screws on each side near the floor of that panel/ Alde cover between the front seats but the "cover" is still solid & I can't tip it forward to peek behind that front panel to see where wires & other stuff is. Where are the other screws to take out so that cover will tilt forward?
2018 Tab 400
Bump— anyone??2018 Tab 400
When I did my conversion I didn't remove that panel. I just screwed a block of wood to it, then built a box around it that I mounted the Lagun mount to. The box follows the contour of the floor and when I fastened it to the block (hidden) I made sure it was pressed down on the floor so the floor takes the vertical load. I'm not able to find it, but I used a tool box wood top from Home Depot to build the box and to use as the top.
Rich2019 T@b 400
Thanks so much for the info & pics! You do beautiful work! Are you using the lagun table as the bed platform for use as a bed in that area? If so did you put the hook attachments on the lagun table from the heavy original table?Horigan said:When I did my conversion I didn't remove that panel. I just screwed a block of wood to it, then built a box around it that I mounted the Lagun mount to. The box follows the contour of the floor and when I fastened it to the block (hidden) I made sure it was pressed down on the floor so the floor takes the vertical load. I'm not able to find it, but I used a tool box wood top from Home Depot to build the box and to use as the top.
2018 Tab 400
Thank you! We don't use that area as a bed, so I haven't set up the table to support the mattress section. If I were to, I would just lay the table on the support structure around the outlet, with some framing to get the height right, and possibly add a swing down leg to the table, similar to the original table. Here's a view from the bottom. The table mount is pretty offset to the front, hence why the support box on the floor comes out so far aft.
Rich2019 T@b 400
Thanks for the pics— I want to do this! Another plus is you don’t have that terribly heavy & cumbersome old table.Horigan said:Thank you! We don't use that area as a bed, so I haven't set up the table to support the mattress section. If I were to, I would just lay the table on the support structure around the outlet, with some framing to get the height right, and possibly add a swing down leg to the table, similar to the original table. Here's a view from the bottom. The table mount is pretty offset to the front, hence why the support box on the floor comes out so far aft.
2018 Tab 400
I have a 2019 t@b 400 BDL and wanted to replace the heavy table. Learned nuCamp put a lighter weight table on later models, so I just bought the new one from them. Much lighter and easier to move.
Haven 220
2026 Ford F150 Tremor 5.0
Niceville, Florida
Hmmm—-What year was is that they changed? What was the cost on the new table?Blueespy said:I have a 2019 t@b 400 BDL and wanted to replace the heavy table. Learned nuCamp put a lighter weight table on later models, so I just bought the new one from them. Much lighter and easier to move.2018 Tab 400
My sincere apologizes, I did not see your question. I'm not sure when the new table was offered, but I think I purchased ours in Augu 2020 and the cost was $135.30. There is a slight size difference according to my wife - she says it's a bit narrower and shorter, meaning doesn't still as far out into the camper as the old. It is DEFINITELY lighter.
Haven 220
Niceville, Florida
