water leakign from water pump under bed
I can use water from city no problem. But when dry camping and using water pump it leaks underbed and has caused mold uner there and will eventually leak out from under bed. When pulled everything out the pump actively leaks slowly when used but cannot tell where from. It is not any hoses but from side or underneath. Does this mean I need a whole new pump?
  • andytabrv
    andytabrv Member Posts: 49
    A few things to check:
    • You didn't mention what year/model you have, but if your camper is still under warranty have your dealership look at it.
    • Check if the leak is coming from the connections to the pump. If those connections are via clamps and the leak is coming from the pipes going in and out, you might try replacing the clamps
    • Check that the clear cover for the mesh filter is tight.  It can be removed by hand to clean the mesh filter and if not screwed back on tightly it might leak
    Otherwise, if the leak is coming from an unidentified place on the pump, then it probably needs to be replaced.  There might be a small crack or failing seal.
    2022 Nissan Pathfinder
    Cary, North Carolina
