We were recently at nuCamp to have some servicing done on our 2019 t@b 400 BDL. I had the chanceto look over a new 2024/25 t@b 400 BD Dark Canyon Edition. Saw some things I liked. The under carriage lights (only one color) so far. I installed $20 strip lights that have lasted four months so I’m good. The under carriage covering. Our 2019 is one large piece and it covers the axle. The new models have harden, molded plastic, that are in sections and the axle is exposed, so much easier if you have to replace it. That got me thinking that I could like to add some reinforcement to the single piece covering on our t@b. I was thinking 2-3 aluminum strips but was wondering if anyone has seen a need for this and/or reinforced this?
2019 T@B 400 BDL
2020 Ford F-150 XLT (V-8)
Niceville, Florida
0 ·
On my yr-18 320S it does not cover the axle as noted for your yr-19 400.
Belly Sheet primary function is to improve the airflow and to stop small road debris from directly striking the underside wiring/tanks . . . which it seems to do just fine.
Reinforcement will add weight with little added benefit. Also, on the 320S the only attachment points are the frame rails . . . no safe center line attachment points which could require heavier gauge metal strips and might make them easier to get ripped off if something does strike the belly. IMHO
Adventures: 54 Nights: 341 Towing Miles 43,780
I'm intrigued with the undercarriage lights you added. Where did you put them and how are they attached?
