Where do the Alde lines heat?
I have a 2024 Tab 400
When I turn on the Alde heater it mostly just heats the bathroom and behind the seat in the dinette.
Where else should be getting heat? Where do the glycol lines go? Do we have a map of the system?
Thanks in advance!
  • elbolilloelbolillo Member Posts: 366
    At the back by the bed. Bathroom. Dinette. And behind the kitchen area.
    Ken / 2023 Tab 400 “La Bolita” (20,000+ miles) / 2024 Toyota Sequoia
    2024 - 2 Trips - 25 nights - 4 National Parks, 3 National Forests
  • pthomas745pthomas745 Moderator Posts: 3,906
    edited October 13
    This thread has a general rundown of the locations of the various convectors.
    Edit: Sorry, I forgot the link!
    How much time are you giving your Alde  to drive glycol around the various convectors?  It can take a bit of time.
    What temperature are you asking for on the control panel?  The Alde thermostat is snug and warm behind the control panel, and can badly estimate the actual temperature in the cabin. Turn the temperature up.  Get a separate thermometer and see if you need to adjust the "offset" for the thermostat.  (In the Tools menu of the Alde.
    You may need to do some Tab Yoga: but what is the circulation pump speed?  Look over this discussion if this continues to be an issue.
    What is the level of glycol in your trailer?   Low heat could mean not enough glycol in the system.
