Hi All, newbie here. We have our 2018 320 CS-S and loving it. Currently in Gulf Shores, AL heading to S FLA for the winter from Cape Cod, MA. Anyway… I noticed water coming out of the fresh water tank external fill last night ( we have been on and off city connections for 2 weeks now). I’m assuming it’s a stuck check valve but I’m not sure where that is or maybe that not the issue? Any input would be appreciated. Thanks!
0 ·
Is that a nautilus system? If so the check valve is behind the little screen in the city water attachment. The manufacturer cautions against manually operating the check valve while the system is under pressure, which can lead to damaging the valve. I assume this means you need to turn off the pump and open the taps and possibly the fresh water tank drain before you mess with that valve. It's a little white button that you can push with your finger once the screen is off.
In my previous rig, the symptoms were: 1) the fresh water tank would slowly over fill when hooked up to city water, 2) The water pump would come on for a fraction of a second every so often. My guess is that a little piece of crud got into the check valve.
Sometimes the problem would fix itself. The immediate solution was to turn off the city water when not in use.
2020 T@B 320 S Boondock Edge, 2020 Subaru Outback
Your description of a very similar problem in a previous RV is likely leading you to the cause in your T@B. The pump used in T@Bs also has a check valve internally and could cause the leak into the fresh water tank you're experiencing.
