Check (Intake) valve for city water sticking?
weaseldog
weaseldog Member Posts: 17
When I hook up to city water: pressure valve to filter to hose to T@B....I won't get water out of the sink...so I remove hose from T@B, push in on valve(?) that is at city water intake connection, will hear a little pop sound and water will flow from inside faucet....seems like a lot less pressure coming to sink than it used to be. Does it sound like valve (or whatever it is) at city water connection is bad? stuck? needs to be replaced?
2014 320 Q Max T@B.   TYIA, Holly
T@B-tini
2 Catahoulas and their Biped
2014 T@B Q in Mendocino CA
TV: 2017 Jeep GC  4x4
    Denny16 Member Posts: 5,430
    Are you in the Mendocino village on city water, or a well?  The water pressure might be a bit low to kick the check valve open?  I am in Casper North, and we are on a well, and GVW noticed when water pressure is low, water seems to effect valve operation.
  • 4ncar
    4ncar Member Posts: 1,072
    @Denny16: have you checked you well pressure switch? Factory defaults are usually 50 psi high, 20 or 30psi low, but both can be easily adjusted. You may also have a failing pressure tank(blue tank near pressure switch). If either are suspect, you may want to consider replacing both with a well pump controller. Save electricity & well pump and have constant well pressure. FYI. I replaced mine years ago and am very pleased with the results.
    2018 320S Outback
  • weaseldog
    Denny16, I am currently in Georgia. I have had this problem in New York, in Tennessee and now here. Not due to lack of pressure coming from city water connection.
    T@B-tini
  • Tampakayaker
    Have you checked your pressure valve before the filter?  Do you have a good flow at the end of the hose before you connect it to the camper fitting?
    Tampa FL
    edited January 2021
    Thanks 4ncar, problem only happens as pressure drops before pump comes back up.  The domestic water comes from a large storage tank, where water from the well is treated.  The pump system in this is set to 60psi cutoff, but pressure drops to 30psi before pump kicks back on.  This was set as a water and energy saving measure, and to reduce the cycle times on the pump.
    The well system is on a well pump Buddy controller system, and we had to replace the well pump and pressure tank about 12 years ago, and relief the well spring box.  So the system is in good kit, just need some more water in the spring box...  :|
  • weaseldog
    I have no problem with pressure from using water tank. Only reduv-ced pressure when hooked up to city water......
    T@B-tini
  • weaseldog
    Tampakayer, no problem with water pressure after filter, brand new one. Ugh.
    T@B-tini
    Well, you didn’t mention the water filter, that would have been my first suggestion...  Glad you got it sorted.
  • Tampakayaker
    I've never noticed that valve you push at the water connection on the T@B.  Maybe it's got gunk on it and it's sticking.  You could try getting some vinegar in there and letting it soak to clean it.
    Tampa FL
    Have you checked the aerator on the faucet?  May have debris.
    There has been some discussion regarding the valve at the city water connection on a 320.  I can’t find it, and I don’t remember the exact issue.  Sorry, not helpful.
  • Verna
    Verna Member Posts: 6,876
    @ScottG and @pthomas745, can one of you help?  It appears that I’m not the only one who can’t remember the name of the valve in the water pipes😉
    edited January 2021
    Backflow valve?  Check valve? This thread discusses the issue of the valve being stuck and filling the water tank, but there is more discussion about the filter, a description of the plumbing routing, and details of the Shurflo pump
    Here is another that discusses the check valve.
    https://tab-rv.vanillacommunity.com/discussion/2756/no-water-help
  • weaseldog
    Thank you pthomas745 !!! "Check valve" at city water hookup.....now I know what to call it and how to look up! I'm pretty sure mine is going bad, the link to video is awesome, THANK YOU!!!!
    T@B-tini
  • Verna
    Thank you, @pthomas745!  Check valve is what I couldn’t remember.
  • ontheroad
    ontheroad Member Posts: 489
    @weaseldog..glad to hear you and "tini" are looked after..see you soon ... hopefully!
    Former 2017 T@G Max XL
    2021 T@B Boondock CS-S
    2018 Nissan Pathfinder
    Ontario, Canada
