Exactly how to open the access panel to the shower water lines?
A few years ago when hooked up to city water, I saw a slow drip outside right in front of the wheel on the driver's side. An rv repairman re-created the drip and said some fittings had loosened up (he said the water pipes behind the shower wall). He tightened them up and I was good for a few years. Now it's doing it again. I would like to see if I could tighten them but cannot figure out how to open the access panel. Is it on the cabin-side of the rig and if so, where exactly? Is it below the TV (2016 320)? I see some molding but just looking, can't figure out how to take the panel off. I looked under the seating there and didn't see any water on the floor. Will try this myself but need some help in identifying the steps. Thanks!!
    I think you can see at least some of the plumbing lines from the driver side bench cabinet.
    mickietucs said:
    . . . cannot figure out how to open the access panel.
    . . . Is it below the TV (2016 320)?
    On TAB 320S with Black Tank Style Wetbath.
    Access the inside Shower Pipes via the long narrow panel screwed to the wall to the Left of the Television.
    Reference:
  • mickietucs
    mickietucs Member Posts: 720
    @Sharon_is_SAM and @MuttonChops - that is awesome information (especially the pics). I should have thought of looking to the left of the TV. Will give that a try. Thank you!
