ARB Dual Compressor > winterization kit
donmontalvo
Member Posts: 187
First camper (nuCamp T@B 320S Boondock Black Canyon. I had to build a winterization kit from scratch. I already had a compressor. I thought I'd share.
[$41.41] VIAIR 90145 RV Winterization Kit
https://www.amazon.com/gp/product/B07DQGNC6H
[$5.99] 3/4" Brass Garden Hose Shut Off Valve,1-Way Restricted-Flow Water Shut-Off, Fits 3/4 Inch Hose Connector
https://www.amazon.com/gp/product/B081NHL9FC
[$12.29] Flexzilla Garden Lead-in Hose, 5/8 in. x 5 ft., Heavy Duty, Lightweight, Drinking Water Safe - HFZG505YW
https://www.amazon.com/gp/product/B01D51VBFS
https://revkit.com/donmontalvo/ | https://donmontalvo.com
Nice kit and parts list. Very similar to the kit I assembled a few years ago and have used with good success ever since.
After blowing out the system with regulated air pressure, I still use plumbing antifreeze through the water pump and the toilet, as I heard these components are the most susceptible to freezing damage. Best of luck with it…2020 T@B 400 Boondock Lite.
2020 Chevrolet Colorado ZR2
with the 2.8 litre 4-cylinder Duramax diesel.
Those are the remaining steps I need to wrap my head around. A few days ago it got down to 20 degrees. I didn’t have a kit. So I drained everything and left everything open.Don Montalvo | Retired Veteran | Full time boondocker
What year is your trailer? The newer trailers have cassette toilets, and different Hepvo sink traps. The pump is very simple to drain and clear water from. Lots of threads on this, so: what year is your trailer?
Towed by 2014 Touareg TDi1 -
This is exactly my setup.donmontalvo said:First camper (nuCamp T@B 320S Boondock Black Canyon. I had to build a winterization kit from scratch. I already had a compressor. I thought I'd share.[$41.41] VIAIR 90145 RV Winterization Kit
2024pthomas745 said:What year is your trailer? The newer trailers have cassette toilets, and different Hepvo sink traps. The pump is very simple to drain and clear water from. Lots of threads on this, so: what year is your trailer?Don Montalvo | Retired Veteran | Full time boondocker
https://revkit.com/donmontalvo/ | https://donmontalvo.com0
