A fantastic little camper trailer. We pulled it with an electric vehicle to Florida and then across to California last winter. It is very comfortable and well-engineered. Has solar panel, charge controller, water tank, heat, air conditioner, ventilation fan, lighting, and more.
The floor plan has a U shaped dinette that converts to almost a king-sized bed 70" X 73"
200 Watt 12 Volt Flexible Monocrystalline Solar Panel
SmartSolar MPPT Solar Charge Controller (Bluetooth) - Charge Controllers for Solar Panels - 75V, 15 amp, 12/24-Volt
12VDC Battery
SPECIFICATIONS
Maximum Sleeping Capacity - 3
Length (ft-in / m) - 15' 2'' / 4.6
Interior Height (in / mm) - 69 / 1752.6
Base Weight (lbs / kg) - 1670 / 757.5
Hitch Weight (lbs / kg) - 155 / 70.3
Number Of Axles - 1
Tongue Weight (lbs) - 155
Air Conditioning (BTUs) - 5000
Heater Alde System works on LP gas or 110v AC power
HOLDING TANKS
Fresh Water Capacity (gal / L)
11 / 41.6
Gray Water Capacity (gal / L)
19 / 71.9
Black Water Capacity (gal / L)
6 / 22.7
Propane Capacity (gal / lbs)
4.7 / 20
Water Heater Tank
INTERIOR FEATURES
Air Conditioning
Kitchen sink, hot and cold
U-shaped Dinette
2-Burner LP stove
Refrigerator - 3 way 1.7 Cubic Ft, runs on 12V, 110VAC or LP Gas
Interior Flooring Type - Vinyl
Shower - outside, hot and cold
EXTERIOR FEATURES
Leveling Jack Type
Front Manual / Rear Manual
Entry Steps
Portable Toilet and small popup tent for privacy
Spare Tire
