We have a 2018 320 CS-S with a rooftop solar array that was added after initial purchase. Our current battery is an Interstate Group 24 with specs HD24-DP
405 CCA 505 MCA. It measures 10-1/4" x 6-7/8”, and is rated for 64 amp hours.
The current battery is several years old, and does not hold a charge well. We are trying to decide whether to replace it with an another lead/acid battery, or pay more and get a lithium battery. We want to make sure we don't mess up the ability of our solar panels to recharge the battery or to power 12-volt use for LED lights and recharging cell phones.
We don't know much about electrical systems, but assume from our limited research that our T@B charging system is compatible with lithium
batteries and can properly manage charging cycles. Is that a safe assumption?
We can get a WEIZE 12V 100Ah 1280Wh LiFePO4
Lithium Battery, Group 24 Deep Cycle Battery that has good ratings and reviews. It is now on sale for $210 (compared to $130 for another lead/acid battery like the one currently in our camper).
Can T@B users with more experience tell us if there's any reason we should not do this, or something that we should check before switching to a lithium battery? [Or is there another make/model of lithium battery you would recommend over the Weize model described above?]
Finally, if we do buy a LiFePO4 Group 24 battery, can we simply drop it in where the old battery was, hook up the battery cables, and be good to go?
Thanks in advance to anyone who can advise us on this battery upgrade,
Will and Kristine
0 ·
2017 T@B S Max, Blue and Silver -- "The Blueb@rry"
You can [likely] go without a shunt if you limit your trailer electric usage as you did with the lead-acid battery. However, a shunt will take the mystery out of your battery state of charge and allow you to confidently power more devices and for a longer amount of time.
As mentioned by others, the internal trailer power converter won't top-off your battery, but there are alternatives for this (such as relying on your solar to do it) that don't require an expensive upgrade to WFCO power center. We use a NOCO Genius battery charger that we already owned (to maintain the battery of an idled tow vehicle). For charging the trailer's LiFePo4 it's as simple as plugging it into 120v outlet, changing the NOCO's battery setting to Lithium and connecting it to the battery terminals.
Administrator Sharon_is_SAM asked several good questions. The answers are that we are hooked up to electric, or shore, power about half the time when we camp. When we are boondocking, it's usually for no more than three days.
Fish Doctor is reassuring that we are on a good track. We will be happy if we double our power availability and also eliminate the possibility of ruining our (lead/acid) battery by running it too low. If our solar panels or shore power can safely charge the lithium battery above 80% of capacity, that would be an added bonus.
Several of you mentioned the charger. We don';t have a Victron solar charge controller, the one we inherited is a CE RoHS Solar Charge Controller SR-HP2440-B. I just got ahold of a manual for it and it does have a Lithium setting, so we will set it to Li. (Apparently we also need to set the "over-discharge return" and "Over-discharge voltage setting," which I don't know at this point.)
A couple of you also emphasized the value of having a "shunt." We understand that to be something that accurately measures the battery charge - is that correct? If so, would that be accomplished by buying a Li battery with a bluetooth app that reads battery level more accurately than our stock wall-mounted battery meter (which also reads black and gray water levels)?
That brings me back to the choice of which Lithium battery. Both the Wieze and LiTime get good reviews. Wieze has a 10-year warrantee, compared to LiTime's 5 years, which instills confidence. However, LiTime offers Smart Bluetooth BMS & Low-Temp Protection via an app on our iPhone, and that sounds like it will give us valuable accurate data on battery performance.
So we are now down to picking between the two batteries, making sure our solar charge controller is set correctly for a lithium battery, and making sure we know how fully the new battery is charged.
We would welcome any further comments about those final decisions, or any thoughts about what I've described above.
Again, many thanks to each of you for sharing your experience!
-Will and Kristine
I recommend purchasing a LiFePo4 battery(ies) with the amp hours that fits your needs.
A Victron 500 amp smartshunt is currently $96 on Amazon. Definitely worth it for battery monitoring.
Ken / 2023 Tab 400 “La Bolita” (23,000+ miles) / 2024 Toyota Sequoia
2025 - 1 Trip - 16 nights - 2 National Parks
Just built a power station with 4X 100Ah LiFePO4's and used the 300 amp SmartShunt. Works identical to the 500 amp.
The explanation of why a shunt is better than looking at voltage is correct but using a shunt with LiFePo batteries is only really needed if the batteries don't have BT monitoring.
Bottom line is that you shouldn't assume that the BMS uses a shunt resistor.
Ask before purchasing if it's important to you.
A while ago I posted about LiFePo charging and as part of my tests I discharged various batteries. I used a simple Amazon capacity tester (basically a shunt with realtime data display) and the built-in BMS tracked the tester closely.
Edit: Ok,ok, let me rephrase. 'requires current measurement'.
2025 Sportsmen 130RD
2023 Ford Maverick XLT
The Finger Lakes of New York
