Using Bluetti Charger 1 to charge lithium trailer battery while towing
I installed a second Victron 75/15 MPPT solar controller in our trailer that has a connector I installe at the side of our front tub. This port lets me hook up suitcase solar panels via an extension cable that can let us park in shade if the portable panels can reach the sun. Having an external solar port gave me the idea to use it with the Charger 1 while towing.
Below shows the 10 AWG cable I made for tow charging plugged into the new Anderson connector port at the side of our front tub. I got rid of the Zamp solar port I initially installed, which isn't marked for positive and negative. The Anderson connectors are red and black. SAE connectors like Zamp's are a lousy design compared to Anderson Powerpole. This is the solar port shown in the photo below: https://powerwerx.com/panelpole-panel-mount-powerpole-black-single?srsltid=AfmBOopQ7WbVkIR0jWh4y3cjIwgsTj9IlIyh2THzgmUjQhdjxQFxz5ZWj-c&gQT=3
Bluetti has been selling the Charger 1 as a kit with installation wire. In the photo below, you can see the heavy 6 ga. wire that comes from the vehicle's battery. I used the gray Anderson SB50 connectors to let me disconnect the charger when it's not in use (big connectors on the right). Bluetti provides a short cable with MC4 solar connectors. I have a cable that runs from these to connect our Bluetti AC180 power station. It should be able to charge at the charger's maximum 56 volts, however I had to dial back the voltage a bit and get a little over 500 watts when charging the AC180. Having a power station is very useful for many different activities.
To charge the trailer's battery via the second solar port I installed, I manually set the Charger 1 to 24 volts (matching the Victron's maximum input voltage), which gives me about 220 watts when charging from the vehicle. Below you can see the Charger 1 and the cable connections.
The installation cable from Bluetti isn't very long, and Bluetti provides a house-type breaker on the end of the cable nearest the Charger 1. It's safer to have your power protection as close to the battery as possible in case there's a short along the power run, so I didn't use the Bluetti breaker and instead installed a weather resistant 60A breaker near the battery. This is the breaker I used: https://www.amazon.com/dp/B08BWM7YH9?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_1&th=1
I used a pair of terminal block adapters to provide solid connection points for the 6 awg wire. Look up, "Recoil BTO Solid Brass Positive Negative Battery Terminals with Adaptor Collars". The wire from Bluetti isn't very long, and I had to cross the width of the vehicle to get to the mounting spot I had picked out. The wire was just long enough to reach, and my SUV isn't a big one. Be sure to plan your installation and get measurements before you start wiring. I had to invest in wire end crimpers and a bunch of cable ends and specialty tools. It may have been no more expensive to have someone who does high power stereo intallations do the installtion, so DIY only if you enjoy it. Note that the smaller gauge wires in the foreground go to a connector for my Noco battery minder. The alternator is standard equipment and the Charger 1 has car battery protection built in.
2023 T@B 320 S Boondock
Amen to that ! The engineer in me recoils looking at these things.
Question though: The setup seems overly complicated. Why not set the Bluetti DC-DC converter to 14.4V (typical LiFePo charging voltage) and connect it directly to the trailer battery ? That would have eliminated the additional MPPT solar controller.
2 -
Is the plan to use the Bluetti Charger 1 with a 24v input to the spare Victron MPPT 75/15 as a pseudo generator to top off your trailer batteries?2023 T@B 320s Boondock, 2013 Toyota Tacoma TRD 4x4 2016 Toyota Tundra 1794 4x4
John, Northern California1 -
bjn2 I'm looking to get the Charger 1 for to keep my Bluetti EB3A Portable Power Station charged while I'm driving. I use the power station to keep my ICECO GO 12v Frig/Freezer running when traveling (I keep it in the back of my Ridgeline under the tonneau cover). I thought the Charger 1 was just for charge Bluetti's portable power stations. I didn't realize you could use it to charge your camper battery. Has it worked out ok for you? Definitely would provide more flexibility. I also installed a Victron Solar Controller in my tub to work with 2 Bluetti Portable Solar Panels I have. So you added another port on the tub just for the connection to the Charger 1 when you want to charge the camper battery?
2018 TAB 320S
2020 Honda Ridgeline RTL
North Texas
Trips - 50 Mileage - @67k
"Our favorite trip will always be our next one"0 -
@rcarlson1957, I added a second Victron solar controller and port in our trailer to allow us to use portable solar panels in addition to the rooftop panel. We camp a lot in desert spots, so if we have shade, we want to take advantage of that. Using portable panels gives us some flexibility to locate the panels in the sun away from the trailer.
The Charger 1 has manual output voltage setting via the app, so you can use it with a wide range of stations. Since power stations are designed to charge from solar within a specified voltage range, you basically just need the correct connector adapter/cable and set the voltage to match what your device can handle. With that flexibility, I've tested the Charger 1 with my smaller Oupes 600 station and with the Victron MPPT controlled port on the trailer. Both work and charge rapidly. I found that my Bluetti 180 needed me to set a manual voltage a couple of volts lower than their default, which is 180's maximum charge voltage spec. Not sure if that's a hardware issue, firmware, or perhaps an advanced setting issue, but I was happy to find that setting a little lower voltage fixed the 180 shutting down charging using the preset for my power station.
I really dislike the SAE type solar port and connectors and I updated the port using with this one using Andersen connectors. Powerwerx PanelPole1, Panel Mount Housing for a Single Powerpole Connector with a Weather Tight Cover | PowerwerxUtah-based
2023 T@B 320 S Boondock1 -
bjn2 Got my Charger 1 in. Going to tackle the install in my Honda Ridgeline soon. Right now I'll just be using it to power my Bluetti power station that powers my frig in the bed of my truck. I have a 3 way frig in my T@B. But I may look at using for dual duty down the road.
2018 TAB 320S
North Texas
"Our favorite trip will always be our next one"1 -
bjn2. Installed my Charger 1 and tested it out with my EB3A station and somehow the DC input quite working on it even though I upgraded the software and set it for the correct station before I started. The station was still under warranty so contacted Bluetti and then sent me a shipping label and sent out for local repair. Took about a week. Works fine now. Good customer service. I also installed an Inkbird wireless thermometer (I use one in my 3-way frig) and mounted it to the Charger 1 to monitor inside temps in the truck bed under the tonneau cover. Can get pretty hot under there in the Texas heat. If it gets too hot the Charger 1 can shut down so I use it to monitor the temps. Figured if traveling and temp gets too high can flip open part of my tonneau cover (it's a 3 panel unit) and the wind should keep it cool enough. Been thinking about eventually replacing my 3-way frig with the 12v ICECO GO 20 I have. If I do that, I'll use the Charger 1 like you do as a DC to DC charger for the camper.
2018 TAB 320S
North Texas
I let Powerwerx know about the Subject Alternate Name (SAN) issue in their SSL cert, preventing some of their images from loading.bjn2 said:
bjn2 I installed my Charger 1 on inside of bed of my truck under tonneau cover. I also put my Bluetti EB3A power bank in the bed and power an ICECO frig off of it. Whole setup worked great till it started getting hotter outside and the temp heats up under the tonneau cover. The power bank will power the frig but get an overtime error when try to charge it from the Charger 1 at the same time. Bummer! So going to follow your lead and run a 10 gauge cable from Charger 1 to my 100ah lithium battery in the tub and just run plug the frig in 12v plug by sink when traveling until I swap out my 3-way frig with ICECO later this year. Curious why you ran it through the Victron Solar Controller instead of going reducing the output and going straight to the battery. I installed a Victron Solar Controller in my tub but use it for my portable panels since I don't have roof mounted ones.
2018 TAB 320S
North Texas
2bjn2 Found answer in Bluetti forum. "I would avoid doing this, the simple description of the C1 is a variable voltage, controlled output load power supply.
It is not a battery charger per se. It will push in 10A constantly at the voltage you set even when the battery should float.
It provides a power source to a power station, which has its own internal charging system. i.e to the MPPT solar input and within its input limit.
I can see using it to charge a LFP battery, but with an MPPT solar controller in between. I have a Victron MPPT 75V/15A. Therefore, the 56V 10A output of the C1 is within the input limits of the Victron for 560W. The Victron then controls the charging Algorithm to the LFP.
In other words, the C1 replaces a solar panel as the power source and is not weather dependent."2018 TAB 320S
North Texas
- 143 Events & News
- 922 Introductions
- 411 Service/Maintenance & Recall Notices
- 75 Teardrop Groups & Links
- 918 Tips & Tricks
