This 2022 T@B 320 Boondock camper has been used 3 times. The bathroom, stove, water, and sewer have never been used!
Two Seabiscuit diamond plate storage boxes were added up front. The battery was upgraded to a 100 amp Battleborn lithium ion battery. An additional Lagun table bracket was installed across from the stove to give the option for more kitchen counter space. A full size matching boondock spare was an upgrade.
Camper has 180 watts of solar on the roof. Dry camper weight is 2000 lbs. This camper is in mint condition!
Graphic: Mountains
Trim color: Jet Black
Sidewall color: Silver
Cabinet color: Natural wood finish (Tan)
T@b 320s Boondock Specs
Custom Ohio-Amish Cabinetry
12v Refrigerator
2-Burner Glass-Top Stove
Expandable Split Bed
Wet Bath w/Cassette & Built-In Sink
Stainless Steel Sink
LED Lights
100 amp Lithium Battleborn Battery (added)
14" Alloy wheels
Aggressive off-road tires
Alloy Wheels
Tongue Mounted matching boondock wheel and tire (upgrade)
Electric Brakes
External Shower
Front Window & Portal Window
Tank/Battery Monitor
In-line Water Regulator
Power Roof Fan
Acrylic Dual Pane Windows
Alde® Central Heat/Hot Water System
Bluetooth® Media Center w/ 19" TV
Central Air Conditioning
Custom Screen/Shade System
180 watt Solar Roof Package
Power Center w/ Lithium Switch
Diamond Plate LP Tub
Pair of Seabiscuit diamond plate tubs (added)
Entry Step Light
Exterior LP Hook-Up
Exterior Lagun Bracket
Extra Lagun bracket inside (across from stove) (added)
Integrated Keder Rail
Nautilus Water Management System
Soft Close Cabinetry
Battery Disconnect Switch
Aluminum Utility Platform
Boondock Entry Handle & Graphics
Rear Aluminum Cage
Heavy-Duty Entry Door Step
Pitched Axle
Boondock Fenders
Total Exterior Length 15' 3"
Exterior Width 6' 8"
Exterior Height 7' 8"
Sleeping Area 71" x 72"
Interior Height 69"
Fresh Water 19 gal
Gray Water 18 gal
Black Water Cassette Tank 5 gal
Tire Size 205/75/14
GAWR 2900 lbs
Tongue Weight (Dry) 190 lbs
Total Gross Weight (Dry) 1,946 lbs
