City water issue
Matilda2xhr
Member Posts: 6
Hello, when I set my water to City Water mode and turn on the water, it immediately flows out via the overflow tube. Anyone experience this and have idea what the problem is? Thanks!
It’s always a good idea to post your year and model number.2016 320 CS-S 1954 Ford F100 2017 Chevy suburban 2023 Chevy Silverado 15000
if you mean, the fresh water tank overflow tube, the check valve in the pump may have failed allowing water to enter and fill the fresh water tank.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Thank you both! By the way, it's a 2023 320S.0
Hi, Here is a thread with a similar issue that is worth reviewing.
TAB 320S BD City Water overflowing2025 360 CS
Southern Maryland1 -
Look under the trailer and find the exact spot or drain where the water is coming from.If you are not using a water pressure regulator on city water, you may have "tripped" the Famous Yellow Flapper valve, which you can find under the driver's side bench down near the Alde. If you are using a pressure regulator, the yellow valve may have just been left open. Look at the link posted by Yoshi that has pictures and descriptions on what to look for.
Towed by 2014 Touareg TDi1 -
THANK YOU EVERYONE! Problem resolved....it was the "famous yellow flapper." Appreciate everyone's input.0
