Need Help Wiring Backup Camera T@B 400
Ontheroadwithdog
Member Posts: 2
Anyone have a little experience accessing wiring behind the bed . I want to tie in a backup camera on my 2024 T@B 400
thanks
thanks
5
Welcome @Ontheroadwithdog and we have lots of members with experience. And feel free to do a search if you have some time to look thru the threads.
I have no idea how to use the forum so thanks for patience0
So no worries @Ontheroadwithdog
It’s a learning curve when you join, and way too much information at once.
First, the title of your new Discussion helps folks find what you are needing help doing
Changing that to “Need Help Wiring Backup Camera T@B 400” and post to the right category (Battery/Electrical & Solar)
As for searching, the Search Icon upper R pulls all the threads that may or may not help
For example, I typed “wiring backup camera T@B 400”
The list of links with the number in each can help you scan.
This one was a few down and has a detailed description of using the wiring of the license plate and it’s route back into the camper, so try that to see if it’s what you need
https://tab-rv.vanillacommunity.com/discussion/12601/2021-nucamp-t-b-400-boondock-installing-rear-view-wifi-camera
So I'm going to update your title as mentioned and move this to Battery/Electrical & Solar so you can find further responses there.
Using the @ before the member name will alert the member that you have tagged them, as I did you with @Ontheroadwithdog
Good luck and welcome again to the forum!2019 T@B 400 Boondock Lite towed by 2016 5.7L Toyota Tundra
5
